41LjH
- City
- Winston Salem
- State
- NC
SOLD ALL /flathead/40 pickup items
Cleaning out the basement ! Cash for local pickup PayPal plus shipping if I ship
Thanks for looking !! PM or CALL 336 422-1956 and leave a message. I will call you
40/41 spare tire mount $75.00
1939 top spare tire mount no rod to running board $50.00
2 original 1940/41 16”x5 “smooth” Ford Wheels. 5x5.5 bolt pattern will fit many early Fords. Been stored inside for 10 years. The tires are still holding air. $225.00
15” Ford wheels 5x5.5 bolt pattern. From a 1980s Ford Truck. 5 1/2” wide, good usable condition, Should clean up fine. $75.00 each $275.00 for all 4.
Top Quality 12 circuit Wiring harness. Compare @$140.00+ New in box
11C 8215 A1 Front hood release $75.00
11C 8215 B Front hood release re-chromed $200.00
Outside Mirror bracket aftermarket $20.00
Tailgate brackets Pair $50.00
2 sets exhaust manifolds $125.00 each
2 engine road-tubes w/ bracket. $50.00 each
½ ton pickup pas. door inside latch assembly. $95.00
Speedway brake proportioning valve #910-31353 New in the box $35.00
Steering column top. Top 4 ½” of a steering column (40 Ford.) including the flair to fit the back of a stock steering wheel. It can be welded to an electrical conduit to make a custom smooth steering column. $60.00
3x2 Edelbrock intake. New never been installed. Hand selected carbs Holley 94s (7RT) tumbled and trued, extended throttle shafts installed. A CORRECT radius 3.5 power valve in the center carb the other two plugged. The idle circuits in the outer carbs are not defeated because all you need to do is seat the air mixture screws. At this point you can either set the linkage(not included) direct or progressive. Speedway Motors gets over $1650.00 plus tax for a 3x2 setup using aftermarket carbs.
$1400.00 takes it all. Including many extra Holly 94 pa
Oil filter canaster Unrestored with feed lines attached $50.00
Complete set of Ford 8BA pistons. These are as removed by the machine shop with wrist pins and rings.. $125.00
40 Valve springs cleaned and pressure tested $85.00
16 aluminum lifters $40.00
8BA Fuel pump stand $25.00
8BA stock cam. $100.00
dipstick w/ tube $40.00
2-8BA distributors $40 each 2- 6 volt coils $10 each 2- 6 volt generators$ 50 each 1- 6 volt starter $70
1941 Ford ½ Ton Radiator This is a correct 41 pickup radiator. It may fit other vehicles as well. Does not leak. Ford moved the filler neck from the side to the top of the tank for 1941 pickup production. $200.00
Sanderson FH1 Headers. Headers with collector flanges and
flange bolts. Driver side bent to clear steering column. These headers do not require gaskets to the block. $275.00. New $606.00
“Car” 49-53 flathead water pumps. Sold as cores. $75.00 for the pair.
Mercury bell-housing TAAC 7505A 1310g with starter plate and lower transmission bracket $275.00
Truck ½ bell housing (small old crack, solid repair) with starter plate $100.00
Transmission side cover 8M 7222. $75.00
Overdrive relay NOT TESTED $20.00
3 pressure plates $15.00 each
4 clutch discs $10.00 each
2 lever shock mounting brackets $60.00
1 Pair Banjo rear end brake drums restorable $80.00
Rear radius rods $250.00 for set.
Custom under dash 5- 2” gauge bracket 65.00
Single 2” under dash bracket. $10.00
Dakota Digital speedometer adapter Ford adapter 50.00
stock speedometer housing marked “19” $20.00
Stewart Warner Electric Speedometer $60.00
Steward Warner Temperature Gauge $35.00
Stewart Warner Manifold Pressure Gauge $60.00
Stewart Warner 80psi Oil Pressure Gauge $55.00
Stewart Warner 60 Amp gauge $40.00
Stewart Warner “coffin needle” Temperature Gauge $50.00
Duel (BAR-PSI 11-160) pressure gauge $30.00
Copper Mechanical tubing $5.00
G1232 synchro set new for S-10 5 speed transmission $50.00
Some pictures attached. PM with questions
