BILL WZOREK
Flat rate U S Postal is the way to go / NOWEVER /
As these pictures show it is very important that the content be packed very tight with out any movement of parts inside the box.
In the case of shipping heavy parts such as SHOCKS DO NOT use those Styrofoam peanuts They bust up into little Styrofoam flakes and don't accomplish any thing.
I learned early on that the contents must be packed tight I use News paper crumpled up and packed in as tight as possable ( with in reason ).
I take the box, close up the cover and shake the box if there is any movement pack in more paper till there is no movement.
I then run 3 rows of clear tape in each direction.
Doing it this way Has worked quite well for Us.
In the Medium Box I Can ship 4 shocks w/arms,links & mounting Hardware by doing it this way.
Not a bad deal for under $13.00 Which now includes a tracking # at no aditional cost.
The problem is that the shipping cost are the same if I ship 1 shock or 4 shocks.
These flate rate boxes work for International shipping also.
Although the rate changes and there are weight restrictions depending where in the world it is going it is still a rate that can't be beat.
When going International there is some paper work to fill out but it's not that bad.
