Flaathead Ted brake kit install
You mean like 39 hydraulics ,I have the prototypes but never went any further ,since the Lincolns are available ,Should I revive the development ,Ted
Absolutely go for it. I'd love to be the USA road test for a set. The Lincoln setup is just too expensive for a lot of us. My 40 would be my test case. I've been wanting to do something with the brakes for years. Come on Ted, you can do it!
Ted>>>I will see what I can do between doing steering boxes>>>
Thanks Ted!!! But how about doing steering boxes between doing Lockheed floaters instead? 8^) Jack E/NJ
Ted,
I have your kit installed and saw a little improvement, but nothing like you show in your videos.
I noticed you mentioned that the shoe material needs to be soft. Does that mean the woven fabric material?
Thanks,
Brad
I have Ted kit in 2 cars. The were a little hard to get adjusted i blame it on myself for not going by instruction. Now i would never have anything else they are great.
Here's some lining # NA3923 woven .NA3812 grey soft bonded,not sure if theses numbers would mean much to you ,Ted
If anyone is confused about types of linnig to use try the Model A site on FB ,or search ,whats good for a A is good for a v8 ,Ted
Ted it would seem that there is a lot of interest. For you to return to this project could make a lot of guys happy and safer stopping.
I include myself with the people who would like you to take up the task.
Phil NZ
Ted, why are the brake linings we should use with the mechanical energizer kit such a mystery. Can you give us the correct mfg. and their part # & where to get? Your direction to the FB Model A site and the search "whats good for a A is good for a v8" didn't find anything?
Thx
I looked at the Ham and that's quite a involved fit up I am hoping to do something simpler than that Lincoln set up ,I will put these through the dealers if successful ,this may need to be in the winter for testing ,
Brake linings The lining numbers I have given are good to use but I don't know if these are USA numbers , I will look into it and report back .What's good for a Model A is good for a v8 ,any search on brakes on the A site will give some useful info. Ted
Here's a picture of the linings previously mentioned ,These can be riveted or bonded ,Ted
