59's are a lot easier than 8BA's (ask me how I know) but you are going to have to make your own motor mounts for the front (pretty easy) and I used a transmission cross member from an F-1 pick up to support the transmission and then if you use a 37 39 transmission with it and the 37 39 rear end you have some fitment details there that are going to require welding skills. I don't recommend the A rear axle. You will be constantly shearing the axle keys. Then you need to modify your radiator re wire, hydraulic brakes etc etc. Get Vern Tardells book on the subject. it shows you step by step although there are some mistakes in it.
I am in the process of doing it and it is a big project in my mind. It is not a bolt in. Would I do it again. Absolutely.
Appreciate you taking the time to reply, been refurbing my coupe and keep getting ?`s on why don`t you fit a V8, it`s easy, just drops in etc., TBH I didn`t have a clue, wasn`t that interested I like it as it is, now I can answer them with confidence.
Having said that I wouldn`t mind a little deuce coupe but over they are quite rare in standard form they`ve all been "got at"
Thanks again, Dennis
Why not sell the old girl and buy a 32 or 33? Unless you need a project I cringe whenever I hear of a decent car being cut up and re-engineered. If you insist, put in an LS2 or LS3 for about the same money as a FH.
I used Mike Bishop and Vern Tardel's book as a guide in building my 29 AV8. I did use a 1951 8BA and got it to fit but agree a 59 series block would be easier. Made up a 39 trans from about five donor trans and used a 40 rear end. Followed the book's advice on how to get it all working with a little fabrication of my own.
Its a ton of fun and steps right out.
Bill
I appreciate your topic on this. I'm doing the same thing to mine I have a frame 2 Flathead. And a trans and rear end from a 39. Ya some people frown on what we do on this sight but I think they forget that's how they hot rodded cars in the 50s so to me and my dad it's still nostalgicBriefly, if possible, what is involved in fitting a flathead in a 1930 coupe?
