thelosthero
so i just got my model a but there was no battery installed so i got one from nappa a commerical 6 volt one all spec's are good i installed it as negative ground, the next day it was low/almost dead so i removed it and charged it. after doing some reading i find it could need to be run as positive ground is there anyway to tell what to run, i read i may need to repoloarise the genorator, im also going to install a battery cutoff on the terminal, could hooking it up backwards could of drained the battery ?
