Jack Shaft
https://www.walmart.com/ip/PRECISIO...=sem&msclkid=7b44818a55671f6bee8ade9fdbd4c06c
anyone try this stuff?
Lay on your back with oil dripping in your eyes trying to precisely set a main bearing doesn't necessarily give good results.nor does it lend itself to a leak free oil pan.Torquing is a pain too.
Just when you think you've heard it all !
If the lower clearances are now good and everything looks fine including the bore this monster just may run fine and not need a rebuild. You'll know in short time though won't you.
I think what you are seeing is the counter balance in the way and just to the left of it, a shadow making the bottom of the rim dark and hard to see.Referring to the pictures in post #25, do I see the skirt of that piston broken away?
