hello all
I went to attach the steering column to the gas tank bracket and it is about 2.5 inches to low and will not go up any feather has anyone else had this problem if so how do I fix it
thank you
kevin 1930 tudor
is this something you took apart or a bunch of parts your putting together? Car wide that is...Victoria's columns hang lower, but im not sure if there is any frame difference other than body mount holes...I should add they ave a spacer between the column and tank bracket....
Try turning the steering wheel. Just a guess maybe the column is down and when you try to lift it the wheels are on the ground and the pitman arm can't move.
