When you get to know the old Marion Mallory designed system that FoMoCo used, you will come to realize how simple it is. The timing was basically fixed with the exception of the vacuum brake to retard spark a bit when pulling a load. It's really rather ingenious in its simplicity but was further simplified in 1942 when the crab came out. The war time years made them develop a more water tight system of high tension pulse delivery so it got a bit more complex with that but still no muss no fuss. The 1945/48 units can easily be converted back to the crab cap design. The old helmet type had everything in one package but with three bolts, it was a bit more difficult to remove for service.
The key is getting a reliable coil and a good quality condenser. The rest of the info can be found on line or in any of the appropriate Ford Service documents. The rebuilt coils from Skip Haney are better than the originals and he has a good guarantee.
