I would think that #4 may be a little high,
or may be this is a typo?
Anyway, I agree with Jack and then repeat the test.
If #2 is still low, put some oil in that cylinder and retest. If the compression comes up, the problem is rings, If there is no or just a little improvement, the problem usually is valves and probably the exhaust valve.
If the problem is rings, continue to run the car and it may get better.
A bad valve will not fix itself.
Chris W.
