bugsiegel
41 I didn't do the install. The braided tube at the rear of the carb you see is actually connected to the wiper. I used the distributor vacuum port since it was not being used.
So I have air entering through the breather but do I still need to allow air fumes to exit or can this stay the way it is? If I need the road draft tube I'll order it. Any other way to let crank case fumes out of the block that already might be present but not shown in the photos?
Thank you guys for you help/knowledge
