38 Conv Well-known member May 29, 2010 #1 Best way to flush trans also drain and fill outlet plug location for 40-41 pick-up trans--- use 85-90 wt lube in trans--140 wt for rear is OK--how many pints for each---Thanks
41PICUP Senior Member May 29, 2010 #2 Take the top off, pull bottom plug. I use 140 wt with some STP in my 41, filled up to side plug.
