Just to let everyone know, the fuel injection on my coupe finally appears to be correctly functioning. While it ran out of the box, there were teething problems Low idle could be corrected by drilling out a pushed in blockage that covered and adjustment torx screw. A harder problem to solve was an intermittent motor stopping at red lights, stop signs and making sharp turns slowly. It gets pretty exciting wondering if the car will start again while stopped in traffic. First replace the throttle position sensor ($29) that did not solve the problem. Checked the internet and found this was a problem with lots of conversations. The answer appeared to be that the idle air control valve could be the problem. Replaced this item ($56) and problem MAYBE solved. Drove car the past two days about 20 miles and no stoppage.
