I got insight that Edmons ( don’t know under what era, 40’s or 50’s ) as they moved the sparkplug location more to centre of chamber.
If a gain I can’t tell as I try look how Edelbrock, Offy, Navarro did and no one or( few ) did this.
If I got it correct head flow dont matter much but get some CR ( ex 9;1 ) head need be around 65 CC.
So porting and sparkplug location is more important.
As I been in racing I think reduce friction from 4 rings and wide cast rings might get some free HP and a stroker crank get less C-H ( light low height piston )
So whst is the case or ’experiance’ on moved spark plug location.
I shore would like see 200 HP from 275 cu;in ( 3.25x4.15 ) and a 3 carb set up.
How wild is a Clay Smith 282-2 cam on aplication ?
My guess find a set Edmons heads might be hard ( if the idea gains )
