GreatLakes28
I am a proud owner of a 1928 Tudor. I've decided to add a trunk moving the spare to the drivers side front fender. The fender on the car is original (no welds or bondo) in great condition. I don't want to cut this one up. I have another fender, I cut out the hole for the wheel well and started modifying it to fit. The arch doesn't come close to fitting up against the underside. When I discovered this to be an issue, I then held it up under the fender on the car, it fit's almost perfectly. The fender I've cut out is suppose to be from a 28 or 29. My question is, is there any difference in Tudor or coup fenders. I realize the 30 / 31 fenders are different. I also ran across a thread here on the Ford Barn, early 28 fenders were somewhat different, but it's just the flange not the curve of the fender. If anyone can shed some light on my fender issue, I would appreciate your input.
