Fender/Running Board sequence?
35window
I wil be installing all of my Fenders, Running Boards, Grille and Radiator on my '35 Coupe soon, and heard that there is a sequence to installing them to get the gaps and everything to fit right.
I've heard that you should install the Rear Fenders and work forward-and I've also heard that you should start with the Radiator and support Rods, install the Front Fenders and work back-
I've also seen (in a Magazine) that they bolted everything together and installed it as a unit (Front/Rear Fenders/Running Boards)-
So, is there a proper way to do this, or do you just bolt-on the Running Boards, pick a Fender and install it? I realize that a misadjusted (or mismade) item can affect the fitting/gap of another-any tips?
Thank you for your replies-
35window .........................
I don't know if there is a proper sequence. Just put everything on and leave every bolt LOOSE. You can tweak it as you tighten the bolts up.
MIKE :)
