Fender Bead Serrations
Charles Reese
Any tips on final painting of fender bead ‘serrations’? after many hours of cleaning them up (wire brush, thread file, etc) I don’t want to loose them again under my paint (PPG Concept). I covered them with 3M green tape while I was doing the high build primer routine so there is a little ‘lip’ at the edge of the primer that I will 400 grit away before painting. Thanks, as always
Charles,
I used PPG Concept on my fenders as well. I took all the precautions you indicated to keep the serrations clean during bodywork. For final paint, I kept the material thin, and applied one flash coat and two wet coats, with the last being the only one I aimed at the serrations. This also kept the crease between the bead and fender surface with very little build up of material, making it very crisp. Good Luck.
Dave Lopes
just the kind of info i was looking for ... thanks!!! i only taped over the serrations so will have to do a bit more sanding where the bead meets the fender. should have asked this question earlier ...
