55blacktie
My 1957 Tbird tach-drive distributor has the following underneath FEJ-12127-A2: H 721. Is H 721 the date code? If so, does that translate to Month (August), Year (57), and Day (21st)?
Due to the different setup, casting and machining processes for tach drive distributors they may have been built in batches, a bunch of them at once, to simplify the turn-around time in creating distributors for the Y-block V8 57's.... Unless many of those distributors were made on the same day, it seems highly unlikely that they would share the same date code. Stranger things have been known to happen.
IF, you were to use just the last digit as the 'day' then it could(?) work, but what about more than 10 months in the year needing another digit?Great photos, but the first and last don't fit the month, year, day pattern. There can't be "61" or "53" days in a month. I'm stumped. ... a 57 owner, who needs an OEM 57 distributor, will find it desirable. ...
That 'could' be for the tenth month, but then you've got Nov. and Dec.Year, Month, and Week can't be right, because two of the distributors in dmsfrr's photos have 0 for month.
