Sid
I am dealing with the early FE bell 153 tooth flywheel. Does anyone recall if the tin plate between the engine and bell housing is required on this early set-up? I don't recall using on early set-ups in the past. I was thinking it was used on the later and acted as a spacer for the later starters. My 61 FE had the spacer but I would like to eliminate if I can.....Thanks
