elliotweiland
I have a 352 fe in my 1963 galaxie. All info i find says that the water pumps came in two versions only. A high flow and standard. For aftermarket they seem to all be high flow but I am finding an issue with the year. All info I find on fe blocks say that they ran from 58 to the 70's. But when I look at water pumps such as Edelbrocks aluminum hugh flow water pump for fe engines, I find the compatibility says it's for 1965 and up. Why would it not fit my 1963? Is this just a case of misinformed manufacturers or is there a change in 1965? My pump looks almost identical to the aftermarket so Im a bit confused.
http://www.jegs.com/i/Edelbrock/350...1&cadevice=c&gclid=CKrO_pDQ38ACFUxqfgodYi8Aww
link to edelbrocks aftermarket. As I said mine looks the same.
http://www.mre-books.com/interchange/interchange18.html
Link to my source on info stating fe blocks had same two water pumps.
Thanks for any help!
