FE 153 tooth flywheel and later starter?
Fabulous50s
I have a 59 Galaxie with a 352. I know some things have been changed over the years as it has a later (wide) bolt pattern bell housing and a 69 Toploader 3 speed.
I am putting a 4 speed in it and have everything out.
It has the early 153 tooth flywheel, but has the later starter. I question if the correct bendix is on it because it makes quite a bit of whine when starting.
I know there is a bendix made to fit the late starter which will work with the 153 tooth flywheel, but how can I conform I have it? The ring gear looks great and the pinion on the starter does too, but i dont think it's that old.
I appreciate the help!
when they changed to that new starter in 65 they changed the flywheel to match thats about all i can tell you.i didnt know you could use the early flywheel.
The two different starters have a similar bendix gear but they are not the same in location & pitch. John Vermeerisch at Total Performance is the guy to contact for a bendix that will work on the 153 tooth ring using the modern lever type starter. His part number is C5A-11350-TP (TP for Total Performance). John has a history with Ford and Ford engines. The gear on his bendix is machined to work so this is not apart number available from FoMoCo. Here is a link for contact:
https://totalperformanceinc.com/contact-us
If he doesn't have one then no one else does.
