Mine is not an LED flasher - it is for normal incandescent bulbs. On the flasher there is current at the "P" (power in) terminal but no current on the "L" (lights) terminal. I think there should be current on both?[/QUOTE
The flashers I have seen have two or three prongs. X is the power; L is the load, and P is the pilot light (not power). If there are only two connections, the pilot light is omitted and there would be just X for the power and L for the load.
[QUOTE The flashers I have seen have two or three prongs. X is the power; L is the load, and P is the pilot light (not power).
Thanks Bill, you have solved my problem!
I did not know what X or P or L meant, and wrongly assumed that "P" meant "Power" and X was for the pilot light. Connecting the wires to the correct terminals based on your letters, instantly made my indicators work!! You saved me a big headache![]()
I am bumping this thread because now I have a new problem: My new 6-volt 3-pin flasher makes the indicators work well (yay!) but it will not make the pilot light flash on the end of the stalk! I am sure there is no problem with the switch or the wiring, so there must be a problem with the flasher unit. I have tried 2 brand new flasher units but neither will make the pilot light flash! I am using 6-volt incandescent bulbs, not LED bulbs.
A retired auto-electrician friend says the modern flasher units are too "electronic". He suggests I buy an "old-school" flasher unit which works a different way. So can anyone tell me what an "old-school" flasher unit is and how it operates and where I can buy one?
