Vermin, my '29 Coupe, has 2 plywood panels, replacing the seat cushions. 2 curved back bar stools are mounted on swivels from Bass-Pro Shop. Try search & you might find pics & description. "Maybe" try RACIN' SEATS.Install a seat setup on a "swivel". Hide the hardware and no one will know. This idea started out as a joke but....
I have to put my right leg in first under the steering wheel then slide in and last pull in the left leg. The last leg has to have the foot turn outward to get in by the seat and the front of the door opening. (Also too fat!). But if the top is down, it is no problem at all.
I guess I'm a freak today with the help my new Wife I've fatten up to 180lbs (6'4") Teenage Daughters --enough said.
Mike, I am with you at 6'4" and 180lbs I feel like a freak. But regardless, getting in and out of our 1928 Tudor is no sinecure. I put my right leg in first as far as I can, slide my butt onto the seat and drag the left foot in. My size 11s often get caught up. Biggest problem is remembering not to use the steering wheel as an aid.
Getting out is easier as gravity is on my side.
Ian
It does seem that a Tudor would be much easier to get into and out of, since you can get the seats much further to the rear! Or take them out sit in the back seat! Ha Ha
Merry Christmas and Happiest of New Year to ALL!
Pooch You still have an 28 Plymouth? I still have Mine...
Included a picture of seat set back
