lh
I set the timing which was retarded causing it to heating up. Much more power and get up and go. Now the idle is too fast. The linkage is not causing the problem. The fast idle 'cam' adjustment screw is loose. It appears that there is a main 'jet' adjusting screw but I did not see a idle 'jet' adjusting screw. I will try adjusting the main screw.
