the-stig
[FONT="]Brakes[/FONT]
· [FONT="]Disc Brakes[/FONT]
[FONT="]o [/FONT][FONT="]Front, [/FONT][FONT="]Use Granada parts (requires minor spindle modification)(need link)[/FONT][FONT="][/FONT]
[FONT="]o [/FONT][FONT="]Rear, Lincoln Versailles (very rare) Consider Ford Explorer 8.8" rear end swap comes with locker and disc brakes not expensive. [/FONT][FONT="]https://www.performanceonline.com/1937-72-ford-car-brakes-brake-parts/[/FONT][FONT="][/FONT]
· [FONT="]Disc brake kits and power brake boosters using Granada or Camaro parts and modified spindles can be found on Ebay.[/FONT]
· [FONT="]Dual Bowl Master Cylinder Conversion
Sadly the member that posted this on youtube removed it,sharing it has helped a lot of guys over the years we thank him for sharing it while it lasted but sure wish he would have left it up.[/FONT]
· [FONT="]This may help in the meantime see post #6 here [/FONT][FONT="]https://www.jalopyjournal.com/forum/threads/tonight-i-am-not-happy.1103171/#post-12515347[/FONT][FONT="] with a 1952-56 you will need a 20" section of 3/16" brake line for the new line you will be adding and some adapter fittings.[/FONT]
[FONT="]If you convert the '56 to disc brakes it may work if it will line up with the mounting holes in the firewall,if you are going to keep the drum brakes you will need to install a proportioning valve in the system to work with the 1990 master cyl.[/FONT]
[FONT="]if going with the power booster kit . get a double diaphram booster not a single.[/FONT]
[FONT="] [/FONT]
[FONT="]Good News! 1952-54 Ford Kevlar Brake shoes [/FONT][FONT="]https://www.performanceonline.com/1964-73-ford-mustang-rear-high-performance-brake-shoes/[/FONT][FONT="] and [/FONT][FONT="]https://www.performanceonline.com/1964-73-ford-mustang-front-high-performance-brake-shoes/[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]1952-54 Brake Drum interchange : [/FONT][FONT="]https://www.jalopyjournal.com/forum/threads/front-drum-interchange.1190043/[/FONT][FONT="] And [/FONT][FONT="]https://www.jalopyjournal.com/forum/threads/rear-drum-interchange.1190074/[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
- [FONT="]Drum Brakes - [/FONT][FONT="]chopd top's thread on drum brake auto-adjust upgrade (using Mustang parts)[/FONT][FONT="] If you need further information on doing this contact him by "conversation" he has quit the Group and blocked me because of a post he saw as political,which you probably should not mention.[/FONT]
- [FONT="]https://www.performanceonline.com/brake-shoes-rear-1964-72-ford-mustang/[/FONT][FONT="] and [/FONT][FONT="]https://www.performanceonline.com/brake-shoes-front-1964-71-ford-mustang/[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
