the-stig
[FONT="]Transmission[/FONT]
[FONT="]T5 Swaps : [/FONT][FONT="]http://www.hemmings.com/magazine/mus/2004/07/T-5-Transmission-swaps/1280831.html[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="]This is a link regarding the Ford AOD used in some swaps,always look for a 1988-93 donor as these have the improved lubrication and upgraded valve body [/FONT][FONT="]http://www.hemmings.com/mus/stories/2006/05/01/hmn_feature5.html[/FONT][FONT="] Update 12/3/2020 additional Tech (It relates to a Mustang but you can disregard some of that) [/FONT][FONT="]https://www.fordmuscleforums.com/threads/c4-to-aod.470612/[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Thinking of swapping out a transmission? New coverage on adapter kits now available here: [/FONT][FONT="]http://www.transmissionadapters.com/[/FONT][FONT="] 223 & Flathead to AOD also late model Mustang stick shift to early engines,call for info.[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Swapping a 3 speed column for an Automatic column when using an AOD or C4.Here's how with pictures:[/FONT][FONT="]http://1954ford.com/forum/viewtopic.php?f=32&t=2951[/FONT][FONT="] Update 12/3/20 Refer to sticky Page 6 for pictures and Tech on the Lokar linkage rod kit which was not available when this was written. The C4 linkage kit is part # ACA-1801[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Another helpful video about a Lokar cable and AOD's :[/FONT][FONT="]http://www.youtube.com/watch?v=T5JediOEQ3U[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Here is an article with pictures showing a Ford-O Matic column set up to work with an AOD: [/FONT][FONT="]http://1954ford.com/forum/viewtopic.php?f=32&t=2951[/FONT][FONT="] UPDATE: See page 6 for new Lokar AOD linkage installed. [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Tech talk on the AOD Transmission
[/FONT][FONT="]http://www.jalopyjournal.com/forum/threads/ford-aod-transmission.1058782/[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]AOD shifting issues ? Rear end ratio may be at fault here is the fix:[/FONT][FONT="][/FONT]
[FONT="]https://youtu.be/qOBO4pvWxZM[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]AOD Transmission swapping guide: [/FONT][FONT="]https://www.diyford.com/ford-aod-transmission-installation-and-swapping-guide/[/FONT][FONT="][/FONT]
[FONT="]Additional info can be found here: [/FONT][FONT="]https://www.jalopyjournal.com/forum/threads/transmission-questions.1149543/#post-13158663[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Tech Tips on the Ford AOD: [/FONT][FONT="]http://www.mustangandfords.com/how-to/drivetrain/1407-how-to-build-the-perfect-aod-aodetail[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="]AOD specs and Identifications. [/FONT][FONT="]https://www.cartechbooks.com/techtips/ford-aod-and-4r70w-transmission-history-and-evolution/[/FONT][FONT="][/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Lokar column shift linkage kit for AOD part# ACA-1807.3[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[/FONT]
