Unless it is loose on the tapered shaft,that fan is not coming off in the car.Take out the water pump,fan and all.Take the nut off the fan,and screw an old head nut on exactly halfway.Then screw an old head stud into the other half of the nut.Screw it down until it contacts the water pump shaft,making it as tight as you can with vise grips.Hold the fan pulley between your fingers,with the pump hanging down.Smack that head stud with a big hammer,hard,don't be a wuss with a lot of little taps.With the head stud and water pump shaft in contact,a hard hit will transmit that energy to releasing the taper.The nut just keeps it all tight and in line so you don't booger up the threads.When you replace the fan,make sure there are no burrs on the keyway,and fit the fan up dry and turn it on the shaft to make sure the tapers match.You can coat the shaft with a magic marker and spin the fan on it to see the contact.I have a couple of aluminum fans that don't come within a mile of seating on the shaft.If the two tapers match,fit the key,and be very careful that the hub seats correctly and the key does not slip up a little.You can tighten it that way,and it will seem OK,but will loosen up shortly.It will ride up with wear,but not in a good way.If you have a new powdercoated fan,make sure it has NO coating in the bore.If it is a new aluminum fan,use a flat washer against the hub.If you don't,the six points of the hexes on the nut will eat into the soft aluminum after a short time.And last,mount it on the tapered shaft dry.I am a big fan of never-seize,and go through a lot of it,but tapered shafts need to be dry to be tight.
