Well I'm a bit frustrated. Just spent a small fortune getting my stock rad recored, managed to get it back in the car (1931 Model A coupe, stock drivetrain) without too much drama. It's a tight fit, but I had about 3/8"-1/2" clearance between the fan and rad. Turned it by hand and everything seemed fine but when I fired it up I modified my nice new rad across the bottom sweep of the fan. Something flexed or ? The rad is now fixed, or a reasonable facsimile of fixed, but I'm not seeing any way to adjust the placement away from the fan.
How much space should there be between the rad and fan?
The holes in the crossmember are designed to adjust side to side not front to back, how can I move the rad forward? I don't want to start drilling and hacking away at an otherwise untouched car, I just don't know what changed. Unfortunately I didn't take measurements off the rad before it went to the shop, so I don't know if it is the exact same dimensions as it was.
