One thing for new model A'ers to remember. A Model A does NOT run hot unless something is wrong. You don't need to run special concoctions of coolants, 50/50 regular green antifreeze will work just fine. No need to re-engineer anything, the cooling system on a model A is well designed for normal everyday, everwhere use. Seal the radiator cap with an O'ring or gasket as you prefer. Fill the radiator as full as you want, let it decide where it wants to level out at and as long as coolant still covers the core, don't add more. Learn how to operate the spark lever, keep it advanced without pinging. Learn what pinging sounds like, don't let it do it. If you are anal about wanting to keep the coolant level high, push a hose on the overflow and run it into a jug, so the hose is all the way to the bottom. When the engine warms up it will push coolant into the jug (or reservoir) and when it cools down it will pull it back into the radiator. It's not necessary but keeps some people happy. If the radiator starts steaming, pull over and let idle for a while then shut down until its cool. Then find out WHY it overheated and resolve the issue, don't accept that it's normal. If radiator or block is clogged up with gunk, its going to be trouble until it is cleaned properly. Another myth: "The water pump pushes more water than the radiator can flow" B.S.! The water pump draws from the bottom of the radiator, through the block so it cannot pump out into the radiator top any more than it pulls from the bottom of the radiator. However, having a partially restricted flow will raise the negative pressure in the block, making it more likely that coolant will "flash" into steam. Water expands something like 1700 times when it turns to steam so it will definitely cause a geyser if that happens.
