Fan Install
Tim,
Back at you......check out the Off'y Regular Dual but for the 8BA motor
Speedway #560-1075. The 8 BA version of this intake positions the carbs CENTERED
on the motor not biased towards the rear as the earlier version #560-1090 does. The
carbs are close together but again are centered. If you use an alternator there is
ample room for everything. Van Pelt has the alt bracket too. Used this setup many
times.
Google that 8BA Offy intake.
Charlie ny
Charlie, thanks for the input. I like the 1075 intake better due to the centered carbs, but since I have an earlier block with a different breather setup, I didn't think this was an option for me. Also, aren't the carb mounts tilted slightly on this intake to account for later canted engine mount?
Yes, to your question on those pulleys lining up.
In my mind, the beauty of using a stock generator on the setup you have, as either a generator or converted to Whitney style alternator, is that all of the single belt pulleys will line up, plus the front bearing system will safely withstand the load of a pulley with fan mounted. I know there are those saying they have mounted a pulley with fan on a regular alternator, or on a powergen with success, but I also know of some of these setups that have failed, and some failed unsafely.
