Just so everyone is aware, the unit pictured is not for an 8BA (car), but probably for a truck. The car uses a sealed bearing (from some other make water pump) that has no provision for lubrication, but can be replaced.
big job;2043257 # 3 Turn fan until the screw is at 12 0'clock fill with oil now turn fan so that oil fill is at 3 o'clock - excess oil will now drain out in a catch pan put fill screw back and your done. I believe that you are supposed to turn the hole straight down to the 6 O'clock position to drain out the excess oil.[/QUOTE said:In agreement with MGG.... Per the Maintenance Manual, published by Ford Motor Co, It says, use one oz of light engine oil, then turn screw hole down, and drain. (TM-10-1375, page O-3-17) (one oz, SAE 20, drain, each 6000 miles)
I just noticed another curious feature of this pulley arrangement and that is there appears to be no seal at the back of the pulley where the shaft protrudes.
Looking at the diagram on the Vanpeltsales page there appears to be no seal there either.
I gather it relies on the various drillings and machined grooves to provide drainage.
Any comments on this?
