jrelliott
Lately the fan blade on my '28 Briggs Body is kissing the bottom and driver side of the radiator. The front motor mount has been modified to accept the later style yoke per Service bulletins. It has a float a motor installed and a four blade fan. The fan at one time had to be tightened as was wobbling on the shaft. The fan is what came with the vehicle but the water pump was changed to the leakless style with stainless steel shaft when the engine rebuilt. The hood lines up good as there is no evidence of frame sag. Any ideas as to what can be causing this problem. Have been thinking of replacing the fan with the newer aluminum 2 blade.
