tjmckenzie
The attached pictures show the top clearance of the fan to the water pump housing and the bottom of the fan clearance to the water pump housing. Should the clearance be even all around. I think it is rubbing on the housing. What is the cause of this? Water pump shaft or fan installation? Thanks in advance.
