Bullrhider
Changed the fanbelt on my '30 today. Got the old one off with no trouble but could not get the new one on to the crank pulley. (I checked - the belts were the same thickness...) It was hanging up on something directly below the pulley. Tried lifting the motor a smidge with a floor jack - no good. The problem was the "foot" of the front motor mount (since the mount is attached to the motor, moving the motor didn't help -- duh!). I finally had to remove the two front motor mount bolts, jack the motor up about 1/16", and the belt popped on with no problem. I have changed other belts so I know it isn't supposed to work this way. My conclusion is the the motor mount is probably an aftermarket item that is just a bit too short. Has anyone else ever run into this problem? I thought about shimming the motor up a touch from the mount but then the bolt holes wouldn't line up. And with all the weight and torque on that mount, I figured it wasn't a good idea? Has anyone replaced the front motor mount without removing the motor from the vehicle?
Thanks for your input!
