thespoiler
I am putting on a new fan belt on my A but having real difficulty because the space between the crank pulley and the spring shackles is too narrow. Any suggestions?...thanks
Jack the engine up just a little. Put your jack under the front of the pan. Protect the pan with a block of wood. You don't have to raise it much, just enough to be able to get the belt to slip on the pulley.
Not enough room between pulley and spring U-bolts? I turn the belt sideways using hand crank turn engine. It will leave some marks on the belt, on an old belt it may cut it into! This is quicker than jacking up the motor. One more belt installing trick is too put the belt on the smaller pulley and start it on the larger pulley, then turn until the belt pops on!
