Fan belt adjustment
I have tried everything to get the final fan belt tension. I used every bar and super long big screw driver off the passenger side water pump. I even tried my cherry picker and put a super strong small rope around the bottom of the fan assembly then I tried a ratchet strap I had a good vertical pull I loosened the bolts slightly not too much or the assembly would ****. I’m I doing something wrong? Gerald
Gerald, use a pry-bar against a small block of wood as a fulcrum between the manifold and the generator.
i might suspect that you're getting it tight enough, but the securing mechanism is slipping after everything is tightened down. ...i'd check that out.
X2
Don't over tighten to protect the fan mounted generator bearings.
I find that the belt gets tighter on a warm motor.
Like has been said, do not over tighten the belt. you'll just wipe out the water pumps and generator bushings or bearings. You want a little bit of play in the belt in the longest section of it. It doesn't have to be super tight and it shouldn't be. I do the same thing as you guys and drive a block of wood under the generator to raise it, if it's still stock and centered on the intake. That way I'm not scratching up anything. I was fleet mechanic, we checked belts on every service, if they had a lot of slop, we tighten them up a bit but never too tight. We always left a little up and down movement in the belts, "a little bit". One thing guys do is use the wrong width belts. The correct width belt will ride on the sides of the pulleys, never on the bottom of there grooves. It gets its strength from the friction against both sides of the bevels.
IIRC, he has a later car with an 8BA. Whatever it is, we should know what it is before throwing out random fixes.
