Kelowna model a
New member
Hi all, just bought a 29 model a.
The fan belt was rubbing the lower rad hose so I pulled the belt and when I had the tension off the fan pulley it is loose. The pulley and fan are tight together, but the shaft sleeve seems to be loose. Not the shaft on the water pump, the sleeve in the fan assemble is tight to the shaft.
Question, is this normal? If not how do I tighten the pulley on the sleeve?
Dave
Dave
