falcon t-10 4-speed trans
tdemo43
Idaho Falls
Idaho
Price
$450
Borg warner t-10 for falcon, ranchero, comet, 62-65 bench seat. I had originally planned to use this ****** behind a flatty in a "32" roadster becase the shifter location is up close to the main case. It puts the shifter farther forward than any other 4-speed ****** I have seen. The end result works great with a bench seat in a hotrod. I completely disassembled it, then replaced all brass syncros, needle bearings, roller bearings, seals and gaskets. Small and compact, No repairs or broken mounting ears. Just add gear oil and run, No disappointmens!!!!!! call for pics or questions 208-524-3995
