Fair price for EAB heads.
Tim Ayers
Still cleaning up for the move. Found a pair of real nice EAB heads. I know some guys like to run these instead of aluminum. What is a fair price for a nice clean set?
Thanks.
Tim
Should be worth a 100 bucks, unfortunately, shipping would be$$$$$ If you are close by just drop them off.
I found a set of 8BA heads at Hershey that had been blasted, magnufluxed, resurfaced and ready for paint for $100. I figured it would cost nearly that to have my old heads made ready with the possibiity of a crack in one or both.
Tim,
Price could depend greatly on whether or not they've been resurfaced (and how much was taken off).
You can determine how much material has been removed by measuring across the recess in the head... I think that the original width is the same as the cylinder bore, 3 3/16". This has been my experience...
Karl
No, the dome of the EAB head is much smaller than the bore diameter. They are not like other Ford heads in that regard.
I'd like to tack this on since it's subject comes closest to my question. While the EAB head keeps boiling to the top choice for stock or slightly modified engines, I wonder if the Mercury EAC heads have the same advantages?
I think the EAC is the same as the 8RT heads. However, I don't trust charts back a few years ago when I was writing my book I measures heads as large as 115cc's. I had a list, but it got lost in the move with most of everything else.
Would it make any sense to know the "stock" dimension from a head bolt boss to the finished surface? I was thinking of a simple tool, like a cut off bolt, that could be used to check a head for evidence of modifications. If a small flat plate was used on the finished surface, milling as little as .010 could be observed. Comments?
