ed stanley
Thought I'd pass my experience of yesterday along, since it may help someone else. (I've been reading some old posts about intermittent and complete failure of modern style points at times. I replaced the modern style points yesterday in my '31 pickup. Wouldn't start after, and I found there was a dead short in the distributor. Checked the small wire between the plates, replaced condensor, checked and rechecked - dead short still. Removed the points and took them to a well lit work bench and dismantled them. The plastic insulator looked fine, but what I almost missed was a razor sharp burr about .040" long on the inside edge of the small stud holding the spring. As soon as the small inside nut was snugged up, the razor edge penetrated the soft plastic, and shorted out to the bracket. I carefully filed the burr, put the points back in, and my old pickup fired right up. Then checked the old points I'd taken out - same thing. Apparently the manufacture, when stamping out these little studs, makes this burr. It's easy to look for, and readily fixed, but a real pain if overlooked.
