dohcdelsol93
I recently made my very first attempt at rebuilding a Ford RTS transmission.
Took me three tries before i decided i got it together properly...took a LOT of grease to keep those needle bearings in that input shaft assembly during installation!
Now that i have the transmission assembled and in the vehicle i'm not so sure i got it 100% right and wanted to as an experts opinion.
1st gear can sometimes not go in extremely smooth, it wont grind, just seems to take a bit more work to find than 2nd or third which shift like warm butter.
and 4th gear likes to pop out and/or grind. The two times i've used 4th gear while driving when i remove it take it out of gear to down shift I then have shifting issues like i'm stuck in gear or between gears. I have to play with the shifter to get it going again. Seems that it takes a few attempts to get it into 4th
I've obtained a little better manual/FSM for the TOD transmission since i rebuilt mine (all new synchros and bearings)
what i noticed was that on the hub assembly for both 1/2 and 3/4 it says not to staggar spring clips, i'm pretty sure i staggared them.
and on one of the hubs the metal levers (3 per hub) have a little notch in them, i'm not sure if the notch faces forward or toward the rear
and last but not least it says there are etch marks in the hubs/sleeves. I looked all over both hub assemblies and did not see any etch marks...was i supposed to put etch marks before disassembly?
thanks ahead of time guys. I plan on digging back into the transmission this weekend and would love for it to go smoothly this time around!
