I got mine from Tim Sheridan in Nunca, MI. His number is 616-837-6477 and his prices were good. His setup uses the stock bell housing, and doesn't have to cut the crossmember. I just cut off the upper and lower ears on the cover of the bell on the front of the drive shaft. The only other thing required was to put two washers under the brake cross shaft to lower it slightly. I went with the trans with the 3.01 first gear and middle overdrive ratio. With a bored and reworked engine, it can still pull up hills in OD. Gets a lot quiter when I put it into OD.
