qmdv
I have an F1 steering box in a 32. Stock frame. I cut the steering wheel end off and welded on an early end with the tapper and key. The slop in the steering is tolerable but I think I want an improvement.
I have been looking at rebuild parts and I have only found the worm gear mounted on a new shaft. That means cutting and welding again. I am assuming that this worm gears are removable so the question is do they sell the worm gear by itself.
