I hate to show my ignorance, but on the F1 what was the original factory location to secure the braided ground strap from the battery? I can not find any accurate information in the service manual. It appears every photograph either cuts off the braided strap from the view or every installation is different. Some posts say on the heads. Some say on the coil bracket. Some say on a starter bolt and then add a grounding strap from the engine to the firewall. I'm searching for the original factory solution and then will also ask if there is a better location to aid in the starting process.
Thanks for your help.
