I've come to the point where I want to run the motor for the first time and park it outside so I can work on the box and the rear fenders. I had this motor running before putting it into the truck but now it just won't go. Some details. This is a 1952 F1 with a 1951 V8 flathead.
1. I installed a 8BA carburetor which I cleaned and rebuilt. I installed a hard line from distributor to the carburetor.
2. I installed a 6 Volt inline electric fuel pump as backup. I have a new mechanical fuel pump that worked previously.
3. I briefly run the electric pump to fill the fuel line and carburetor.
4. I tried starting it with 6 volt battery but it cranked over slowly but wouldn't fire.
5. I could get it running briefly using a 12 volt battery and pouring some gas down the throat.
6. I went for a tea break and when I returned the coil had blown up. I'm pretty sure I had left the key off.
7. I installed a new coil. Won't fire even with 12 volt boost and gas down the throat. Mechanical pump doesn't seem to be pumping any gas. Can an electric inline pump wreck the mechanical pump on a 239?
I'm fresh out of ideas. Any advice would be welcome and appreciated.
