kiwitony
Hi Guys , I've been working on a 52 F1 thats just been imported from the states.Its a neat old truck and I've been going threw it doing cab mounts,carby, oil seals etc. The clutch trust bearing was noisy, so pulled the gearbox as I was doing the side shift seals as well. The trust bearing was so stuffed it had been spinning on the hub and worn that as well. Got a new hub all the gearbox seals and new trust bearing. Trust bearing to my concern was made in china. Put it all together and started it up and the noise is still there. I'm devistated, I can't belive that even a chinese trust bearing can be bad from new. If you push the pedal down so that the pedal is pushing on the pressure plate it is quiet, but if you move the pedal in and out it makes a sqealing noise. I'm now thinking the pilot bearing is bad. What are your thoughts? I didn't delve deeper into the clutch when I had the box out as I figured I'd found the problem on finding the rooted trust bearing. Any advice greatly appreciated as I don't really want to pull it to bits again,I want to go fishing. Cheers Tony.
