B Duncan
Hey Group,
My truck has developed a bad bumpsteer problem. It started all of a sudden, but I need to give a lil history. Please bear with me! I have owned my 53 F-100 for over 12 years. 6 years ago I added the standard eye mono springs to lower it 3". I had radial coker classics for tires. When these tires wore, I was unable to afford radial white walls, so bias coker classics are on the truck now. These tires have been on the truck for 3 years. Last year I hit a pothole in the road and for the first time I thought I had lost a tire. I had to come to a complete stop to get the front end to quit shaking. I know these bias tires drive different than radials, but nothing ever like this has happened. Last week I installed a rebuilt stock axle with new kingpins, tie rod ends and a new drag link. Toe is set at 3/16", and I have added 4 degree shims (read online that this would cure bumpsteer). Took the truck on a test run and bumpsteer was worse than before. Any thoughts or ideas on how to fix this? Less caster, or will I have to install radial tires... The Bias have been balanced 3 times since this first happened. No change! Thanks in advance as always guys.
