pat Well-known member May 16, 2012 #1 will 58 f 100 front brake and hub assemblies fit 53-56 f 100 spindles ?
A alanwoodieman Well-known member May 16, 2012 #2 I have been told that up to 64 will work-should be easy to check out. I also know from experience that 77 bronco 2's are the same
Ken Crans Well-known member May 29, 2012 #3 I believe that 57 thru 64 will work for the 58. 48-56 are the same. I think all that is different would be the inner race and bearing.
rich b Well-known member Jun 4, 2012 #4 The backing plates and hubs do not fit the earlier spindles. The bolt pattern on the plates is different, the bearings are different both in size and spacing. The shoes, wheel cylinders, springs, and drums will interchange.
