fordhistory
Hi guys,
I've almost got my '41 convertible converted over to F-100 brakes on the front. Everything was working well until I went to hook up the brake hoses. The original '41 brake hoses will not screw into the F-100 brake cylinders..., the male threads on cylinder end of the '41 brake hose are too big (I think 7/16 vs 3/8). And I can't use the F-100 brake lines, because it's a different female threat at the end which hooks up to the steel line. What to do? What to do?
I know there is somebody out there who has done this same conversion. What brake lines did you use? Do you have a part number I can reference. Did you use an adapter?
Henry Dominguez
Henry Dominguez
