kiwitony
Hi guys I've been working on a 51 F1 for a mate. It's a recent import from the states and a neat old truck. Motor runs sweet now with a bit of work, it's tired with only 30psi compression but can be hardly heard at idle. He [the owner] will only do a few hundred miles a year, so I figure it will last a long time. My issue is with it graunching when going into first and reverse gear. I've tried putting into second or top which is fine and then engaging first but it still grates. I've adjusted the free play several times and it makes no difference. My 18 speed roadranger has a clutch brake for this very reason but these old girls shouldn't need that. I'm leaning towards oil on the disc causing drag but I'm open to all suggestions. Thanks in advance Tony.
