Rich Largent
I have a 56 Victoria. The door button rod will sometimes ride up over the actuator lever if pushed in too far and gets stuck in place. I need to remove the outside handle to see what's going on. Any tips for the removal process?
You have to remove then inside handles and the upholstery to get at the screws holding the handle to the sheet metal. Removing the inside handles requires a special tool.
